Really important question...
Started by RobMatthews, February 11, 2007, 06:22:58 PM
RobMatthews
as above i have a really important question but i\'ve forgotten it so if anyone knows the answer please let me know the question.
parts supplied by;
DM-Motorsport.co.uk
Info@DM-Motorsport.co.uk
Crazy Eddie
Q: Should I become a full club member?
A: Yes :D
Warthog
Q. Is this a question.?????
A. Yes if this is an answer.!!!!
Project Evil seven.:evillaugh
RobMatthews
crazy eddie is correct now for question number two what is an oil catch tank and what does it do ?
parts supplied by;
DM-Motorsport.co.uk
Warthog
#4
OCT--It is fitted into the oil return on your oil filler neck. It collects all the blowback oil which is gunk. It is very useful if you are doing track days as it stops any oil blowback from going on the track under heavy braking/cornering.
e.g. link   http://www.viper-performance.co.uk/products.php?cat=62
Hope that helps.:wave
If the link is not showing the pic, then click Home, Kits & tab down to it.
RobMatthews
so where would the gunky oil normally go? would it be just mixed in with all the oil going around the engine?
parts supplied by;
DM-Motorsport.co.uk
Warthog
Yes.......................:2eek
Thats one reason why a lot of people fit one. HTH.
RobMatthews
so does the oct seperate the good and gunky oil ?sorry about the dump questions!
parts supplied by;
DM-Motorsport.co.uk
Warthog
The blow by oil is pushed through the new piping into the O.C.T. and then you just empty it when full. Easy. If you are doing a full track day you will look to empty it a few times in the day. Normal road use it can be many weeks. HTH.:wave
It\'s a safe mod--do it.
