just a little turbo.....specs
Started by dubber91, February 10, 2007, 09:18:19 AM
dubber91
Hi guys,
Looking at the potential of putting a little turbo on a NA motor as they do quite commonly in the states. Either way, i dont wanna run mega boost, for obvious reasons, and have been offered an Airesearch turbo relatively cheaply. What A/R specs should i look for. In adition to some A/R specs (that im waiting for) It has
50mm air outlet
70mm air intake
2x35mm exhaust inlet
68mm exhaust outlet
Whatcha reckon? what A/Rs should i look for?
antnicuk
minimum of 0.86 hot and 0.60 cold i would say.  I put a Cossie T3/4 which is the big one from the early escorts cosworth and it was way too small for a stock TII lump.  Needless to say, it had NO lag at all.
Why dont you just put a stock Tii turbo on it?
travellinbob
Hey I saw this turbo for sale on vzi and looked very similar to the one i sold to a guy to put on his mondeo?!!!!!!!!!!!!!!
 Considering you would have to buy and fit an external wastegate maybe a stock turbo would be an easier start? Mind you on re-looking at the  specs it is a bit bigger than the one I didnt want to put on my 12a...
 cheers, michael.
dubber91
ah ok......it is probably worth just looking at stockers then.... What boost did you see on the cossie turbo?
Steveo
antnicuk
i only ran 1 bar, but on cossies they run  2 bar.
the exhaust housing isnt big enough though
