knocking noise of
Started by yamaster, February 07, 2007, 07:14:28 PM
yamaster
im having problem with the car. when i take of hard or spin the wheels i get a load of what feels like axle tramp. its a realy knocky noise and it seems to be coming from inside the prop shaft. is there an inner and outer part of the prop shaft and is this a common problem?  there is no bushings gone. when i lift the back wheels of the ground. and put it in gear and let the clutch out i get a knocking noise for a second
banned advertiser
check your diff brace and mounts, doubt its your prop but check bolts are secure.
TRex
100% Diff mount bushes...
 2hr job at home with the right gear...
yamaster
Quote from: rotaryart.uk.comcheck your diff brace and mounts, doubt its your prop but check bolts are secure.
how will i check these?  and where exactly are they??
Quote from: TRex100% Diff mount bushes...
Only way you will stop the diff jumping up n down is a set of solid mounts which is the kind way with no bad viberations or a diff brace.
yamaster
Quote from: cliveOnly way you will stop the diff jumping up n down is a set of solid mounts which is the kind way with no bad viberations or a diff brace.
but this is REALY bad. i know its not right
Carl
#7
Hi Shane,
Give me a call in the morning.
Regards
Carl
