Relocate air temp sensor
Started by nikp, October 06, 2006, 02:58:41 PM
nikp
This may be of interest to people who are fed up of their air temps heat soaking when sat in traffic.
http://www.negative-camber.org/crispyrx7/ait.htm
I believe that, even if you have the original plastic elbow, a nut on the inside should hold the temp sensor in place, but it does depend upon how much thread there is in the sensor.
Rixio
Very nice find nik :Thumbs-up
Worthy of a sticky :)
Jonathan_F
Never put a nut on the inside!!! If it falls off its in your engine and out through your wallet!!
There is enough plastic. Its a M10 x 1.25 thread.
nikp
QuoteThere is enough plastic. Its a M10 x 1.25 thread.
what do you mean by this? you mean put a tap into the plastic, and screw into that?
rx7veilside
buy a greddy elbow much safer tapping into alloy than plastic
Jonathan_F
Quote from: nikpwhat do you mean by this? you mean put a tap into the plastic, and screw into that?
Hi Nik. I\'ve tapped a plastic one and a Greddy type elbow. Both have held at 1.1 bar. Use a rubber washer and nip the sensor up.
Jon
nikp
Cool - nice one. May be brave enough to try that on mine. Still need to sort the wiring on the sensor i got off you!!
Jonathan_F
Quote from: nikpCool - nice one. May be brave enough to try that on mine. Still need to sort the wiring on the sensor i got off you!!
I am trying to find the right plug to fit the sensor.
If anyone elso wants one of these high speed sensors I have few left please PM me or ring 07779 11 69 43 and I\'ll post one to you.
They eliminate the heat soak problem completely.
Regards,
Jonathan
Jonathan_F
Nik, I\'m working on getting you a plug.
Anyone else need a sensor PM me.
They eliminate heat soak.
Jon
07779 11 69 43
efiniste
I could do with a plug too Jon if you find a source.
alexb
Jon, you have PM.
Cheers,
Alex
m4drx
is this or a triumph one advisable with a stock ecu?
how does this benifit by seeing colder or realtime temps or to put it the other way what effect does a heat soaked high intake temp have?
cheers
fduk.
Jono FD3
#12
Jonathan F, Can\'t PM you mate your not a full member???
Anychance of an email with all the prices etc for the new sensor???
My email is: info@d-signstudio.com
it means that the fuel mixture is aulterd more than it need be.... basicaly a quicker reacting sensor will give a better fuel mix ofor the intake air temps!!
Jono
m4drx
m4dsup at hotmail dot co dot uk
fduk.
Jonathan_F
Hi Guys,
Sorry, I\'ve been away from the forum beavering away in the garage.
Jono - your right, by reacting more quickly the ECU should be able to fuel the car correctly more of the time. I work for a motorbike company and I\'ve questioned some of the fueling guys. Their supposition is that the slow acting sensor Mazda used is either a throw back to the non-turbo charged engines when changes in inlet temperature would have been due to ambient changes and relatively slow, or, they have used it to smooth out the engine. I imagine that from a heat soak to 20 mph scenario (at the lights after a blast) as the sensor(my fast sensor) cools rapidly you get a change in fueling from rich to correct and the engine response may change  - feeling non-linear. This would of been a negative for test drivers etc. Its only a theory. I\'m purchasing a logger + wide band AFR so shall be able to log the two sensors later in the year.
In the mean time, e-mail me at Jonathan.f@hotmail.co.uk if you would like a sensor and plug. I can also source a small bolt that blocks the old sensor location if you want to relocate to the elbow (where heat soak is less evident).
Regards,
Jon
