Apexi and air pump?
Started by ro284, February 10, 2007, 08:38:17 AM
ro284
I have set up my Apexi or is that called initialised it? anyway iv\'e got the car running ok, but i completely forgot about the air pump! i have since disconnected it and it still runs ok, but it will have learnt it\'s maps for the engine with the air pump cutting in and out,would that make any  difference and should i reset the Apexi and start again? any info gratefully recieved,
Regards Bob
Hi Bob,
I wouldn\'t worry too much because providing you had all of your other electrical equipment on the EUC would hove been seeing lots of electrical load going on whilst it was working out what it had to operate,
The air pump (when connected) cuts out at revs so it won\'t interfere with the map Apexi map when above 2.500 revs.
