Which injectors?
Started by Ian@TunerUK, January 24, 2007, 05:11:47 PM
Ian@TunerUK
Right, just running the car in now, I\'m running (what I think is) a street port, decat HKS exhaust, Apexi twin induction, stock twins and it\'ll mapped with an Apexi ECU/commander.
Now I\'m guessing to get the most I\'m going to have to uprate the injectors? If so what size/sort will I need? Also will it be usefull to get a Walbro fuel pump at the same time? Again what sort etc...
What sort of power at what boost should I be looking at with these mods once fully in and mapped? Fly and wheels figure guesstimates...
Ian
peterwolds
Ian i had additional injectors added to plenum and a walbro 255L pump,got 305RWHP - have power fc ecu on
:Typing Pete
Ian@TunerUK
Quote from: peterwoldsIan i had additional injectors added to plenum and a walbro 255L pump,got 305RWHP - have power fc ecu on
Is yours running the street port?
peterwolds
Quote from: Ian@TunerUKIs yours running the street port?
stock twins no porting(except wastegate had to be opened up due to exhaust i had fitted),twin induction kit,greddy smic & boost controller
:Typing Pete
gsb876
Depending on how far in the future you want to go with power it might be an idea to get the 1600 secondary injectors with fuel rail in now, otherwise you might spend money getting 1300\'s in but in the future want more power???
1300\'s are good for over 400bhp, if you are gonna go over say 460bhp then 1600\'s would be better.
Walboro fuel pump should do the trick, or a BNR33 fuel pump ??? :yes
John Yorke
With a street port to maxamise the potential you will need additional fueling, most cars hit a wall at about 280ish rwhp on stock fueling, to get the best you need bigger injectors or additional ones, both have thier advantages, simple way is to go bigger [1200\'s or 1680] others have gone for 850 all round [this tends to give a lumpy tickover/ low revs lumpyness] or add an additional pair [550] with this you would need an extra controller which adds to the expence.
All the above options you would need a bigger fuel pump [me I would go for a skyline or Supra pump] and a FPR then get it tuned by one of the banners on this forum and you should see some good results providing you have all the other bits in place.
HTH
Ian@TunerUK
Cheers for the info guys! It\'ll be getting set up by Pip at WGT so I\'ll be asking what his thoughts on the matter are aswell, just wanted to get some other opinions first :Thumbs-up
peterwolds
Quote from: Ian@TunerUKCheers for the info guys! It\'ll be getting set up by Pip at WGT so I\'ll be asking what his thoughts on the matter are aswell, just wanted to get some other opinions first :Thumbs-up
Ian pip fitted these additional 550\'s same time as walbro
:Typing Pete
