The best part of owning an RX7....
Started by RedRummy, January 13, 2007, 12:46:04 AM
dreamers
Best I had was a guy in a ford puma trying to beat me off the lights.
Enough said.... you know the result. After 1 second he gave up :Laugh
ruffryder
Quote from: RedRummy... for me, is not having to do 3 point turns anymore...
Turn the wheel, give it some revs, drop the clutch...
BOOM - 180!!
:Thumbs-up
 i did that  for the 1st time yesterday - great feeling :Thumbsup!
Mims
probedb
I like flooring it down slip roads then realising you\'re going waay faster than the people in the outside line by the time you get to the end and having to slow down...oops. Not that I would be breaking the speed limit of course ;)
pete sparrow
There\'s so many brilliant parts to owning a rex!!! The smlie she puts on my face every time i look at her! The admiring stares and the long looks when she\'s in the sun changing colours,people just captivated by the changes!!Kids stopping dead in their tracks,rushing to get their camrea phones out to get a picture. The noise the car makes,and when the screamer pipe kicks in and the power say goodbye everything bar italian exoctica! I could go on,but i won\'t:o :o
Warthog
It\'s the most fantastic Supercar that we can own and it eats other Supercars for lunch..................:evillaugh
Project Evil seven.:evillaugh
RedRummy
Quote from: PETE SMITHWhat is "LIM" RR??:evillaugh
Lower Inlet Manifold... or was it the Upper Inlet Manifold...
as you can probably guess, I drive it, I don\'t fix it!  :Hammer
"Life moves pretty fast....
Ferris Beuller, 1986.
RemarkLima
Quote from: RedRummyfront tyres are different to the rear.
And I *may* have slight suspension issues, not sure yet - its going into Re:Worx on tuesday for a full service....   Feels fine to me, but they said I should get it looked at when they fixed my LIM before Xmas..   :reallymad
TBH It\'s probably worth getting matched rubber (as said, it make such a difference!) and a full geometry check and setup done, i.e. not just toe that CrapFit do but check the castor (should be fine), toe and camber of all four wheels with half a tank of juice and a 70KG (we\'re averaging here!) sack in the seat ;)
I need to get mine done once I get the new suspension on, can\'t wait :D
moosey
Quote from: PETE SMITHTis true,
Had a burn with a Carrera gt4...he gave the respect sign and we went our own way.:driving
Now, would a Beem/Merc do that???.................i doubt it.........it\'s a funny old world ain\'t it??:rollin :p
Used to have a Merc C43AMG and the answer was/is yes, at least in my case.:god
mikeyh
as said before decat lol
sitting in 2nd gear then lifting the throttle just as u pass and old person and a dog and the car lets out on ealmighty pop/bang and you see the dog **** bricks lol.
or flooring it and as u lift u get huge flames from the rear(not that ive seen  it but been told)
yamaster
the best part of owning a rx is the looks i get anywhere i drive it.  puts a huge smile on my face every time i start it up.
C-WestRZ
once u learn to drift it, -assuming its set up for it-
u wont stop, its just soo much fun.
RedRummy
Quote from: RemarkLimaTBH It\'s probably worth getting matched rubber (as said, it make such a difference!) and a full geometry check and setup done, i.e. not just toe that CrapFit do but check the castor (should be fine), toe and camber of all four wheels with half a tank of juice and a 70KG (we\'re averaging here!) sack in the seat ;)
Yeah, I mean to get a full geometry check, but have other more pressing worries....  :(  see thread here
RemarkLima
Bummer! Good luck getting it sorted!!!
Iain C
just sitting in it and starting it up.
You also never know if your gonna make it back!
