Bonnet Damper / Gas Struts for Turbo II
Started by Prof, January 15, 2007, 03:08:26 PM
As per the title - does anyone know - has anyone got or used gas struts on a Turbo II bonnet ?
If so what make?  And any bad points from experience ?
Many thanks in advance...
Prof. :cheers
grinder
i nearly fitted some to mine but never got around to it
you will have to let us all know how you get on :D
The tightest man on earth
:Giggle
I will.  I\'ve seen several going cheap on eBay  (I must learn to stay away from there) - not sure if they would fit an RX7 - but it doesn\'t look like the hardest thing to make one fit.
I was looking at the ones for MX-5\'s - company in Germany were doing some for about £20 the pair - finished in black as well. I should think a TII ally bonnet isn\'t too much heavier than an MX5 one ?
I can then get rid of the prop at the front and hide all my relays and things behind a nice ally panel. :driving
grinder
ah yes - i have seen the ally panels
they still work with the relays and prop in place
i spotted them on ebay aswell :D
its been very quiet on FC parts recently though :(
:Giggle
tell me about it.  I am trying to source a water injection solenoid as well - but they seem to have all but dissapeared now.
Yep. I got some on my T2.
Not hard to do at all, I bought a Polished alloy Lifter kit from E-bay (off a VW tuner) the instructions where easy enough.
grinder
oohh water injection - now thats a nice toy :D
:Giggle
Quote from: grinderoohh water injection - now thats a nice toy :D
I have most of what I need - coolingmist kit - but with a solenoid valve I can have 2d mappable water injection :D
grinder
i looked into it - but i think they are expensive for what they are
a pump and a spray head ??
unless its me being cheap again !! LOL
:Giggle
No - going for a full on water system.
Inspired by Brett\'s DIY mister unit for the TMIC, I am going to fit a couple of sprayers for the uprated intercooler, but also a full WI system, the solenoid is just so I can map the water injection duty cycle according to boost / rpm.  This should make the water last a little longer.
Both systems will be run from a large ally tank in the boot - so this will be a water only system - not water / meths.
Should take care of heat soak and charge temps :driving ;)
Hark at me hijacking my own thread !
