Tips on shaping carbon fibre please?
Started by scooby_si, December 14, 2003, 06:55:41 PM
scooby_si
Right got a couple of small pieces missing from my soon to be cars rear spoiler, which is no longer made so no replacments, but i have or am going to be supplied with some carbon fibre to shape to offending missing bits & stick in there to look schweeet!
I\'m told it\'s just a case of hacksawing to a reasonable size then filing to fit pucker. Is it this simple &/or any tips greatfully received....
Also wots guna be best way to stick bits on: just sum half decent double sided tape or art there further cunning plans?
Cheers peaps
Si (AKA technical retard lol)
J4P RX
Surely its supposed to be made in the shape you need.  I would think just cutting a sheet apart might look a bit rough.
Lee
scooby_si
well it\'s a long piece of carbon fibre i\'m getting so i should have plenty of trial & error bits but no not possible to have it made to fit unless you know sumwhere that can do this?
I did wonder about how solid the CF could be cut but presume roughness could be filed/sanded easy enough to a smooth & properly shaped finish but hey as you can tell i no sweet FA lol
So anyone with any experiance of shaping CF? or any other cunning plans/options woodnt hurt
Si
missing bit:
emicen
Thats a really small bit missing to go to the hassle of chopping up a big bit of carbon fibre to fill. Why not shape a piece to fill the hole out of fibre glass and make on for the other side and then get cheap carbon fibre film and stick it over the top. If you want to to look like pukka carbon, spray a couple of layers of laquer over it (thats what usually gives away film ;) )
craig
do it with fiberglass m8 cutting bits of fiber will lokk well dogy  fiberglass is easy to shape and use
scooby_si
hmmm interesting so u did ask for it
Wots the story with fibre galss ie where to get & how to get to correct shape size etc & how to fit to hole?
Si (deeeeeeeeeeeeeeeeeeer )
johnf
Si
I\'d use a sign material \'dibond\' - I\'ve got some offcuts you can play with so it\'s got to be worth a go.
scooby_si
Cool John i like signs lol serious i will torment u/take u up on that offer
Si
