commander prob
Started by Travis, January 26, 2007, 02:07:55 AM
Travis
took the rex out today and noticed the inj duty on the commander was on 0% then if i reved the engine it worked again then done the same again when driving along then 30 secs later started working again,any ideas chaps?
                                      cheers keef
Crazy Eddie
Firstly I would check the sensors in the PFC menu to see if they are all working correctly. This should tell you which are not functioning propperly.
From there I guess its a case of checking the connections and making sure none of them have come loose.
Travis
Quote from: Crazy EddieFirstly I would check the sensors in the PFC menu to see if they are all working correctly. This should tell you which are not functioning propperly.
nice one mate :yes
rx7veilside
#3
mine goes to 0 when i put the clutch in and change gear and comes back as i rev i thought this was normal
if u rev the car stationary in neutral what does it do does the duty cycle drop to 0 and come back up or does it just drop to about 4-5%
same test when driving what does it do
Travis
mines never went to 0 until now i aint had a chance to look at it yet,will probably take a look tommorow,but even when driving mine went to 0..then when i reved would come back on again:reallymad
