milky oil
Started by bev johnston, December 19, 2003, 12:18:54 AM
bev johnston
I checked oil and was thick and milky.  Dealer said was condensation.  Could this be?
Fishy
Bev, sounds about right. At this time of year a rotary gets a lot of gunk around the oil filler cap.
Depending on how long ago an oil change was done, might be worth doing a change.
Dan
bnaellis
What do you mean you checke dteh oil ? You mean you checked the dip stick ? If you got milky stuff on the dipstick then your definitely have oil mixed with water= rebuild soonish. If the milky stuff is just on the oil fillcap and neck then it will be condensation.
rgds
