difference between pre and post 95/96 rex?
Started by nextleveluk, December 29, 2006, 11:19:15 AM
nextleveluk
G@NDY
One difference is the ECU, older models have 8bit and newer have 16bit....
..errrr anyone else:rolleyes:
Is the Efini pipe metal on 96+ cars also???
nextleveluk
yeah, just found that out, thanks....was wonderin if there is anything else?
thanks gandy
michaelb
Quote from: nextlevelukany details will be apprieciated
thanks
Hi
I have a 96 RB Bathurst…the main difference is the ECU and also, the cat is only in the mid pipe, there is nothing in the down pipe unlike in the pre 95 cars…as far as I know.
Regards,
Michaelb
Ricco_04
Only UK cars had the pre cat in the down pipe.
Thought there was a list somewhere to tell you the difference betwene the Zenki & Kouki models?
Arn\'t the clocks diffrent? or am i thinking of the 99 spec cars?
TRex
95 will have an \'N\' plate.... 96 will have a \'P\' plate....
 I\'ll get my coat..... :o
20B_boy
Quote from: GrizzlyArn\'t the clocks diffrent? or am i thinking of the 99 spec cars?
Pre 96 are orange, post 96 are green, pre 99 has an oil pressure gauge, post 99 has a boost gauge...
R.
Quote from: TRex95 will have an \'N\' plate.... 96 will have a \'P\' plate....
How would that work if its a December 95 or Jan 96? Would\'nt they both be N reg?
:rollin
TRex
