line lock
Started by D1 WTF, December 19, 2006, 02:13:01 AM
D1 WTF
where can i get it from and how much does it cost?
how does it work, is there a button you press and hold, or what?
is there any damage this can cause (not including tyres)?
could it put too much pressure on dif, causeing premiture death etc?
i would use it for strip, and maybe, the occasional bit of showing off.
dubber91
there are two types.....one electrical, one mechanical. The mechanical type are nothing but a stop that interrupts the brake line and needs to be plumbed into the place on the dash or in the footwell where you want it to sit.
An electrical one means the actual lock only can be hidden away, and a switch wired up to the gearshifter or dash etc.
I prefer the electrical one.....its neater to install and your less likely to knock it whilst your driving!
http://www.streetstyleandpower.com/publicRouter.cfm/loadPage/108?cftoken=16484028&cfid=3664772
at the bottom of the page.
JAMAR make mechanical line locs...but i dunno where to get them from over here....
Steve
D1 WTF
can anone else answer any of my questions
antnicuk
#3
I have a hurst roll control line lock which comes with a solanoid that you just plumb into your fron brake line as it leaves the master cylinder and before the abs unit (before its split into 2 for left and right)). You then have a simple electrical connection to a switch in the cabin (push an hold type).  To use push the brake pedal, hold the switch, the solanoid then holds the pressure in the front brake lines by shutting the solanoid, you can then release the pedal, allowing you to smoke the back wheels while the fronts are locked, just release the button and the front brakes release and away you go.
No damage to anything really as long as you are sensible using it.
D1 WTF
cool, i like.  think i will look into getting one in the not to distant future.
dubber91
it puts strain on ALL transmission components. Engine will be fine unless it gets damaged for another reason (wear, apex seal goes etc). You can brake transmission mountings, break props, snap half shafts, **** the diff, or just end up massively wearing it (loads of side float etc). You might do this if you get silly. Just like dragging your car, you might break it if you rag it too much or kill it from cold. Theres no fool-proof way of preventing damage occurring.
Steve
antnicuk
all of the above could also occure by just wheelspinning your car without a line lock,  i would say the line is better for your car if your gonna burnout the tyres as you can engage things more gently rather than just dumping the clutch.
carlos
can i say ive been behind antnicuk wen he has lit it up!!!!!! havent i tony!
antnicuk
Quote from: carloscan i say ive been behind antnicuk wen he has lit it up!!!!!! havent i tony!
I dont know what you mean!!!     :burnout :burnout
Warthog
Sam,
 you nutter why didn\'t you ask when you were out with His Royal Hoggness as I have the full monty fitted ( As Ant\'s Post, red button in car) works well had no probs with it. Find out how much a new one is then make me an offer via PM, you have first dibs as you have asked and I will be selling it off in Jan anyway as I am only going to be doing Track Days next year.:yes
Project Evil seven.:evillaugh
carlos
lol nice 1 tony!!!!!! o is that me evo...... sob sob
