3rd gen turbo problems?
Started by mikeeech, December 04, 2003, 10:57:01 AM
JimboRX-7
That is very low, unless you\'re running in a new engine perhaps ?
Standard boost pattern is approx. 10-8-10
93type-x
hi ,
Im getting the same thing with my import , with the high boost then nothing , I checked my ECU and found a "knight sport FCD" connected to it.:D
still getting that now it works now it dont thing, Im hoping to get the chance to get to uk before rotorstock and get pip to work some magic
si
Ric
QuoteOriginally posted by JimboRX-7
Excuse my ignorance here but what does 10-8-10 actually mean?
I assume the figures are PSI but why three?!?!
ric (rexy has gone now all I have left is NFSU2 :( )
iaint
QuoteOriginally posted by peace2make
It\'s referring to the boost pattern accross the turbos.
10 PSI from 2.5k RPM - ~4k RPM
8 PSI as the 2nd turbo comes online (~4k - ~4.5k)
10 PSI from ~4.5k rpm up.
That also equates to ~ 0.8 - 0.5 - 0.8 in bar.
There is usually some trail-off on the 2nd turbo at high rpm not that you usually have time to look.  Passengers help!
Iain
