Disabling ABS?!
Started by Initial-D, December 02, 2006, 07:35:36 PM
Initial-D
I\'m aware you can remove a fuse to do this, but there are infact two fuses!
ABS unit and Abs valve on one fuse and another larger fuse which does ABS pump motor, ABS unit.
Should I pull both?
I want to test out the brakes as is and possibly rid myself of the ABS as I find it kicks in too often on track. I beleive they also run our pads down quicker too.
Ben
antnicuk
just disconnect one of the sensors near the wheel,   there are plugs that connect the sensor wire to the loom. You only have to disconnect one.  That will stop it working.
