Fuel Pump Earthing help
Started by m4drx, November 28, 2006, 11:04:27 PM
m4drx
HI guys,
can anyone shed any light on how the fuel pump is earthed and where the wires go, ehat the silver box does & the little one with 12v dc on it but attached to a ground point i suppose?
i have taken some pictures of the area in my car but mostly stock, i can email them if anyone wants to see.
this all comes about from the fact that my car has a bad earth. it has extra earthng kit on the negative terminal but i havent yet traced & repaired the standard earths.
i am confused to say the least!
fduk.
asp
iv had a bad earthing probs,every wire or wires that bolt to the body of the car unbolt them and use a little sand paper to make it better,.i know you cant get every one but some better than none,
m4drx
Quote from: aspiv had a bad earthing probs,every wire or wires that bolt to the body of the car unbolt them and use a little sand paper to make it better,.i know you cant get every one but some better than none,
tried tried tried as per my other threads but i have neglected the old ones off the battery which are apparantly important according to the below?
what do you think?
http://www.aaroncake.net/rx-7/grounding.htm
fduk.
m4drx
fduk.
