Induction kit?
Started by ramirez, November 24, 2006, 08:10:43 AM
ramirez
Anyone got one of those HKS induction kits for their FC turbo?
Seen one for around £150 - do these make much difference on RX7s as the one I had on a Prelude made diddly squat difference?
nikp
Inudction kits don\'t really make much of a difference at all. It\'s mainly going to make things worse by sucking in hot air.
It\'s a lot less restrictive than the stock filter, but make sure it gets cold air if you really want big benefits.
I run one of these green mushrooms, and will be making a cold air box for it.
With a good exhaust system the induction kit really pays off, but don\'t bother with it unless you have decatted. :Thumbs-up
Brett
A decent panel filter does the job too :)
Brap Brap Brap Brap
nikp
Quote from: BrettA decent panel filter does the job too :)
Absolutely right! :)
ramirez
Quote from: ProfIt\'s a lot less restrictive than the stock filter, but make sure it gets cold air if you really want big benefits.
cool it is decatted. Incidentally the previous owner lived in Camberley, you might recognise the car? It\'s a red T2 coupe H reg?
I think I saw it about once or twice, but I think it was a \'weekend\' car.
What spec was it ?
The heated air intake issue is only a problem when the car is sat in traffic - a well designed cold air box will take care of that problem.
The intake ducting has several places where it\'s restricive - the MAF sensor, which narrows a lot, the intake piping goes through 2 90 degree bends to clear the air pump, and the turbo inlet is 2 1/2 inches so that\'s another restriction.
If you want to run more than 300+ power you will have to look at some of these things - a panel filter probably won\'t cope at these higher powers.
