ACV removal
Started by allstaruk, November 03, 2006, 03:49:31 PM
allstaruk
Then you might as well remove the ACV the other reason to do it is if your fitting a top mount secondary fuel rail you\'ll need it gone.
blackrex, if you need it explaining let me know and i\'ll scrawl out a quick guide to removing it.
A
interloper393
what the weight of the cat pipe, air pump and all the acv gubbings? must be a fair bit :)
allstaruk
ACV and pipes not a lot at all, with the airpump quite a bit its a heavy old lump. Its handy clearing up the spave for air flow round the turbo\'s too.
Al
rx-paul
http://www.mazdarotaryclub.com/forums/showthread.php?t=30180
this is the link remove the valve and blank it off there is a small solinoid next to it dont remove this just the acv
blackrex
Quote from: allstarukThen you might as well remove the ACV the other reason to do it is if your fitting a top mount secondary fuel rail you\'ll need it gone.
A
A quick guide would be great please mate
cheers
mark
