Antifreez mix??
Started by Jono FD3, November 02, 2006, 10:29:04 AM
Jono FD3
I dropped the water lastnight and flushed it through with some fresh........ droped the water again then filled it up with some blue antifreez!! I put it neet in to the expantion tank to the top mark, then put best part of 4 litres in to the engine, so not quite a neet mix as there would have been some water left in the rad & heater matrix!!
Fired it up & ran it for a while befor letting it cool & check the level ( Needed a slight top up)
Basicaly is it OK to run this strong a mix of anti freez in the water system as I have just found my water leak and dont want to create anymore issues!!!
Thanks in advance guys!!
Jono
nikp
Sorry, not an expert on the mix.
but interested to know where your leak was?
interloper393
i used to go with 70-40 for antifreeze, but im sure i read somewhere that 100% antifreeze was ok but dont quote me oniit lol
Jono FD3
Hai Nik... The leak was so obviouse it was unbileavable!!!
When I was fitting the aftermarket sensor I unbolted the filler neck from the engine, & when I put it all back I didn\'t realise that the sensor was touching the filler neck slightly!! just enough to stop the "O" ring from sealing properly!!!!
Cheerse for your help & tips on the problem though!!
Jono
