Re-positioning the rad
Started by Fats, October 22, 2006, 03:45:11 PM
rmagictastic
Quote from: SmiftaIs that a quote from the Mazda service manual !!!
To be honest I am planning on ditching my a/c, for airflow purposes. Did you remove the pump/compressor at the same time? Did you also remove all the piping and stuff too? I suppose if you just remove the a/c-rad you could always refit and refill later?
Cheers,
Alex :)
why for airflow??  seems alot of work for a very little gain??
Rmaj
Getting old... Its not like it was in my day!
Smifta
Why for airflow? I have a large HKS frontmount, so the flow is already impeeded, the a/c rad sat RIGHT in front of the upright coolant rad can\'t be a good thing! Also, since I fitted a HUGE PWR race rad space is very tight.
310 atw. Stock twins. Mazdaspeed GT-Concept.
nikp
Quoteand be carefull when you dump the gas from the AC, do it outside, loosen a joint of the pipework, hit it with a harmmer to open the joint and run like hell!!! It wil scare the sh*t out of you, did me hehehehe.
Technically, removing the gas from an A/C system yourself into atmosphere is illegal - depends whether you care or not. I got a qualified air con man to remove mine. Only cost £30.
rmagictastic
Quote from: nikpTechnically, removing the gas from an A/C system yourself into atmosphere is illegal - depends whether you care or not. I got a qualified air con man to remove mine. Only cost £30.
absolutely correct it is illegal (technically)
Rmaj
memski
Agree with Ant, make your own brackets. That\'s what I did, ditched the a/c and custom fitted a hks gt fmic.
NurburgRob
The Rad is only positioned like it is because Mazda wanted a low front end, if the rad was vertical thefront wouldn\'t be the shape it is.
