Bloody coolant buzzer
Started by Tintin, October 23, 2006, 05:49:00 PM
Tintin
My bloody coolant buzer won\'t stop , there is loads of coolant in so thats not the problem
Pip things I haven\'t plugged it in properly , but I can\'t find were he\'s on about
I\'ve plugged in the sensor that comes off the front of the water pump housing , Pip has mentioned a single wire connector behind the p/s pump that connects to a lead coming off the block but I can\'t find owt loose off the block
What I have got though is 3 single wire connectors around the back of the p/s pump but I\'ve also done away with the a/c pump so I don\'t know if they went to that . One of the connectors comes off the harness that comes over the top of the engine , the other 2 are low down on the harness that comes up the side of the engine
Someones gotta help me , I only got her running for the first time today and I can\'t drive around with the buzzer going off its driving me barmy
One other question , does the ecu and the temp gauge in the dash have seperate sensors ? I ask because a while back I did the temp gauge mod and now I have an apexi I was wondering if it would cause problems if its the same sensor , apexi readings look okay but better safe than sorry
12.8@110.64 at RS4:Thumbs-up
