quicky :P
Started by interloper393, October 21, 2006, 08:50:05 PM
interloper393
If i add a front mount intercooler, does this replace the radiator i.e means i can remove it? or am i totally wrong.. does an intercooler not run air instead of water lol.. gunna get slated for this but i aint got a scoobie... :WaveBye
ScuttleRX
No you still need a radiator matey :)
Intercooler cools the intake charge, only need them on turbo\'d/supercharged cars as pressurising the air increases the air temp a lot.
Radiators for the engine coolant so you need this whatever
oldone
Quote from: interloper393If i add a front mount intercooler, does this replace the radiator i.e means i can remove it? or am i totally wrong.. does an intercooler not run air instead of water lol.. gunna get slated for this but i aint got a scoobie... :WaveBye
Must be the cold air up north !!!:spank :Laugh :rollin
interloper393
ahh right, so if i add a front intercooler, alloy rad, alloy ast, remove bat to boot, remove aircon, then am i right in saying the airflow will be greatly increased and engine temps a be way lower and reducing the chance of detonation?
ScuttleRX
Your air temps will be a lot lower. Engine temps (coolant/radiator) will stay the same I reckon, it can be a prob with front mount intercoolers as they block off some of the air flow for the rad. Although it will still be alright, especially as you plan on uprating the rad aswell.
interloper393
forgot to say a re ad-9 ventted bonnet to will be fitted.. hoping to make her as reliable as poss before increasing the power :D
Can you get bigger rads that a fit without major mods under the bonnet?
