Noob in Bristol
Started by FTORich, October 11, 2006, 10:20:53 AM
FTORich
Quote from: RotaryRepair.co.uk"Something not quite right with that compression test on a rotary!" ?
Hi I was the guy that went out to do the compression test last night
(Greg from Rotary Repair Services).
The engine was showing "average to good" (my words) compression using the standard compression tester with Schroeder valve removed method.
97-97-97 psi on front rotor and 96-96-96 psi on rear rotor.
(That’s 6.7-6.7-6.7 & 6.6-6.6-6.6 in bar)
I wouldn\'t say anything was indicating that things were "not quite right".
This link here by Clive suggests that I should be adding 20% to figures from a "normal compression tester":
http://www.mazdarotaryclub.com/forums/showthread.php?t=107&highlight=compression
I record exactly what I get from the test gauge, and those figures I gave do not highlight any problems.
Greg
Hi Greg, sorry if it came across that I was having a go at your work, you obviously work well beyond the working day ;) Had a minor panic that an engine that both looks and was reported to be fairly new, looked to be on it\'s last legs.
Rich
RotaryRepair.co.uk
Quote from: FTORichHi Greg, sorry if it came across that I was having a go at your work, you obviously work well beyond the working day ;) Had a minor panic that an engine that both looks and was reported to be fairly new, looked to be on it\'s last legs.
Rich
Hi Rich,
Thanks, dont worry I didnt feel that you were having a go at me.
I entirely understand how you must have felt, and just thought it would be better to give you a bit more information about what those pressures meant to put your mind at ease.
Greg
davehg
hi people, in from yate (bristol) work at Airbus... well when im not in dresden, germany lol ive got a red single turbo FD, should all meet up at some point
FTORich
Well just fiitted a Head Unit in to drown the squeaking I haven\'t got round to sorting and found all the speakers were stripped with the HU!!
On the plus side the car also has a Knight Sports ECU!  :)
