Help needed!
Started by D2BBA, January 26, 2007, 06:24:52 PM
D2BBA
Thanks mate, will check those tomorrow when light.
Just one last quickie tonight...where does the TPS switch live, so that I can check / replace.
Thanks!
Chris
rx7veilside
tps is on the rear of the throttle body is black and rectangular with i think its a 4 pin plug and will have to screws which loosen when u adjust it
K1HKS arse
Look at throttle body from passenger side of car.Left side of throttle body is throttle cable,right side(baulk head side) is black sensor with 4 wires going in.Underneath throttle body coolant hose.
You can check for air leaks using brake cleaner fluid,spray it in a fine mist around pipe connections/engine bay after throttle,if idle changes you have an air leak.
D2BBA
Cheers lads, will have a go tom!
Over and out.;)
Chris
