19" rims
Started by craicedup, September 25, 2006, 08:22:38 PM
craicedup
About to buy a set of 19" racing hart rims 10X19 rears and 9x19 on the fronts will i have any problem fitting these.
cheers
tr1cky
depends alot on the offset you have!?
The FC is dead, long live the FD
craicedup
offset is 30mm
275/35 tyres rear
255/35 tyres front
LRP
Quote from: craicedupoffset is 30mm
275/35 tyres rear
255/35 tyres front
not sure if that will clear the brakes cant remember what my offset is ikll  find out
complete wankel :god
tr1cky
et30 offset on a 10 inch is poss getting abit tight on space.
with a 9.5rim the ideal offset is et35mm(ish), so going wider and lower offset both push the wheel out more.
Have the arches been rolled at all? If mot then this will prob need doing to gain that extra few mm\'s can make all the differance!
As for clearing the brakes, depends what set u you have and the style of rim, not offset.
craicedup
Havent rolled the arches but ive got hks hyper d suspension with the camber adjusters if that helps checked the rims last night the rear offset is 43 and the fronts are 38
tr1cky
Quote from: craicedupHavent rolled the arches but ive got hks hyper d suspension with the camber adjusters if that helps checked the rims last night the rear offset is 43 and the fronts are 38
Them offsets won\'t be right, but give you room to use spacers and get it spot on. again the coilovers will give you a little more room to play with.
craicedup
Thanks for the help
jamie_eaton
if it helps i have a set of 20"s on mine, no rubbing no problems
