RX7 rebuild - number 2!!
Started by Bobfish, August 29, 2006, 10:58:51 PM
Bobfish
Grizzly; short answer - no.
As you can see i put quite a thick coating on. I like to use hylomar because its a piece of **** to clean off!
interloper393
the more i see threads like this the more i wanna rebuild a engine lol.. still looking for the right car then its all good.. :) just gutted ma garage and build a nice new workstation for the rebuild..YaY!
Quote from: BobfishGrizzly; short answer - no.
But is\'nt Blue hylomar designed for use with a gasket? Where RTV isn\'t? I was told to check out the Grooves in the Legs (which was full of grey sealer) so i replaced mine with that.
But each to there own, if it does the job.
Bobfish
Just a quick update - the engine is fuly built and ready to go back in today. I picked up my alloy rad for my 7 today too. Hoipefully by tomorrow night i can have this car done, which leaves me until next friday to fit my rad, fix my oil leak and get a 4 wheel alignment on my car.
Bobfish
Went from this:
To this:
And received this (thanks clive at Shy Auto! Your a star :))
should have it started tomorrow.
mullins
Quote from: Bobfishsee photo, i actually used 2 bolts here but you can just slide it over the dowel. Obviously though 2 bolts is more secure.:
Thanks mate. I got it off last night. I ended up using the hit it with a chisel method!:Nono!
