length and width of an rx7???
Started by Baz116, September 26, 2006, 09:51:36 PM
Baz116
Hello!
just cleaned out the garage for my new 3rd gen rx7, looked at the space left and thought, hmmmmmmmmm.... will it fit?!:3Confused  (don`t pick it up til tomoz(hopefully) so cant just try it for size!!)
Does any body know the length and width of an rx7 3rd gen??
LeedsLad
4295x1760(mm) mate if you need height check out here i found them the other day to see if mine would fit in my garage but it wont :reallymad
noyzboy
If you can get it in, can you get out of it !!!!.
If you can\'t, don\'t put it away after washing it without giving it a run to dry the brakes ( good exuse), else you\'ll have a Rex in the garage that you can\'t move \'cos the brake discs have rusted, and you can\'t get in the car to drive it out !!!!
Baz116
just measured the garage, loads of width so i can drive it in! length should be ok... might have to make some alterations to my dads workbench... sure he wont mind...:2Rolleyes
thanks guys!
