Fitting A Boost Gauge - tips?
Started by Pedro B, July 10, 2006, 07:27:43 PM
Pedro B
I am fitting a boost gauge and am having trouble finding an "easy" route to get the pipe through into the cabin. Any tips or tricks?
Current plan is to go out into the wing then back in by the door elec harness route in front of the door hinge.
I am struggling to get it through any current harness routes.
Thoughts?
Thanks all,
Pete
Eddie
Hi
I used the passenger wing route, behind the arch liner and into the cabin, easy but I am sure you may also find a route from the drivers side as well.
I have made a little cut on the rubber going around the throttle cable and pushed the pipe in there.
Pedro B
thanks guys, I will have another go...
cheers
probedb
I was lazy and drilled a small hole down in the footwell :) I\'ll sort it out properly when the engine is out.
ro284
If you\'r feeling a bit daring, you could try here with a dremel, it comes in to the car just above the clutch pedal bracket
ro284
#6
Found the pic,iv\'e got boost tube, temp sender capilliary, and a couple of wires through the grommet now, this position gives you plenty on the tube etc ,as it\'s so close to the gauges, but it\'s a bit critical position, certainly no lower than this or you would hit the clutch bracket in the cabin,
good luck, Bob
FD3SNuttah
im fitting a gauge as well. can anyone tell which hose / where the best place is to "T" the boost gauge?
ro284
Looking from drivers side at the upper inlet manifold, there are 3 vacuum tubes, the first on the left,(nearest bulkhead) goes to the brake servo,(thick black tube) the middle one is probably blanked off, this is where the boost tube goes on to,(in place of the cap thats on there now.) the one on the right goes to the standard BOV
hope this helps
Bob
Mart160plus
For the firewall I went through the grommet that the bonnet pull goes through.
1993 RX-7 Type R2 321bhp at the fly
1973 TR6 French Blue needs a fuel pump
Maybe Honda Jazz or Polo GTi in the offing...
All pics on www.ballisticmart.com
[SIGPIC][/SIGPIC]
Pedro B
Hello all,
In the end I drilled a small hole about 1" to the left of the throttle cable hole, which I think is v similar to bob went (see above). I had no problem but sealing access is tricky, in the end I have used silicon as I struggled to get a grommit to fit.
Thanks all,
Pete
imebgo
Push a coat hanger through the engine side through the firewall and through the steering boot comes through nice and easy.
The vacuum tube goes onto the upper manifold theres a capped off nipple on the left side looking at it from the front.
Put some hose over that and tie it up with a cable tie, should be fine.
J
