Remap blues
Started by cannonballer, August 14, 2006, 06:44:03 PM
rmagictastic
what should i try???
filling the tank to the brim and doing another run???
Rmaj
Getting old... Its not like it was in my day!
John Yorke
If you are on the stock fuel pump and injectors you would have to run the tank very low to induce this problem. Might be worth investigating the wiring to the pump though as this has been known to break down, after all these cars are mostly 10+ years old and things like wiring have a shelf life.
rmagictastic
Problem solved, fuel starvation.
im running Bosch 040 with 850 primaries and secondaries.
filled the tank right up (it was on just over 1/4)...ta darrrrrrr!  no problems.
Rmaj
