fmic fitting questions
Started by bobert, July 05, 2006, 08:07:02 AM
bobert
I am thinking of putting a trust fmic in my fd. I have had a quick look around my engine bay and it does not look very easy because of to the way that the radiator is positioned. I have not had a good look at how people mount them but I think that you have move the radiator up right and sit the intercooler in front of it, this means that a couple of coolant hoses have to be changed.
can any body post some pics and give me a bit of advise of how they have mounted their intercooler, what I need to take off and what extra parts I have to buy.
rob
rmagictastic
i just fabed up some simple brackets to get the rad at a bit of an angle, about.. 30 degrees i rekon, so there is a bit of distance between it and the I/C
Rmaj
Getting old... Its not like it was in my day!
bobert
I am in the process of fitting my own fmic, do you still have any of those mounting brackets you made up for your rad
rmagictastic
just went to B&Q, got some 25mm wide, 4mm thick steel, bend in vice, drill some holes....T\'Daaaaaaaa!!!
Rmaj
