Replacing Metering Oil Pump
Started by IanFiTheDwarf, July 18, 2006, 02:42:59 PM
nikp
TD06_FD
I was thinking to remove the pump, I assume when you remove it the heat light will keep flashing, how can you avoid this?
Bobfish
To remove the lines you should really remove the OMP, belts, UIM, rats nest, fuel rail, fuel lines, AVC, bla bla.
Its not really that simpler job.
Red and Single
Quote from: BobfishTo remove the lines you should really remove the OMP, belts, UIM, rats nest, fuel rail, fuel lines, AVC, bla bla.
Can I Just remove the OMP and leave the lines in place untill it goes bang one day and then get the lines removed at that point ??
Dave Hughes
