Is this any good...?
Started by khyber pass, August 10, 2006, 04:03:29 AM
khyber pass
Got a bog standard exhaust with the twin pipes out the back....
Wandered if this cheap exhaust was an OK option, and if it would be compatible with existing downpipe??? I have no idea.....
The advert...
MONGOOSE STAINLESS STEEL EXHAUST SYSTEM WITH 4.5" STRAIGHT CUT TAIL PIPE
THIS IS A FULL SYSTEM NOT INCLUDING THE DOWN PIPE.
THIS ITEM IS STRAIGHTFORWARD TO INSTALL AS A DIRECT REPLACEMENT FOR THE ORIGINAL SYSTEM AND COMES WITH NECESSARY FIXINGS
THIS ITEM IS SUITED FOR THE FOLLOWING VEHICLES:
MAZDA
RX7 TWIN TURBO
 FD3S MODELS
A7NTY
Can these Mongoose systems handle the enormous heat? Thats the question. In my experience on other cars they are generally pretty decent exhausts.
As Ant says can it handle being burnt like mad.
Contact them and ask if they pack the silencers with good quality stainless steel wool of the like as you will blow conventional stuffing out like you have a pee shooter after yer Rotary has dumped some fuel in there and then lit it for amusement:)
