Ignition Barrel
Started by AshRX, August 06, 2006, 07:55:59 PM
AshRX
One of the teeth in the ignition barrel has broken, so the key wont turn in the barrel.
How easy are these to change over for a new barrel?
93type-x
check with mazda first,,,, but i am swapping out the whole column, but mine was broken into ,,, it does come appart if you do try to strip it watch for the little yellow box thing on the side.... that snaps off its over.:eek:
