I.C. air duct removal?
Started by oddball, August 04, 2006, 10:25:31 PM
oddball
I have removed the ic and removed bolts holding bracket which holds air duct to car front and ic.  What else is require to remove air duct from the car.  I cant see any other bolts.  Any help would be appreciated.
oddball
Jit
which is the air duct? is that the plastic shroud tye thingy that feeds air to the ic?
oddball
oddball
Jit
mine was just held on by 2 bolts at the front of the car....and thats it!! Ill have to have a look at it again tommor w and see if there is sposed to be anything else holding it on...
oddball
Sitting infront of the battery there is a round silver tank about half the size of a coke tin with two pipes bolted on to it which feed upwards.  The right hand side of the air feed fits around the tank.  I dont know what the tank is for, but it is that thats stopping it coming out.  Any ideas?
oddball
Crazy Eddie
Quote from: oddballSitting infront of the battery there is a round silver tank about half the size of a coke tin with two pipes bolted on to it which feed upwards.  The right hand side of the air feed fits around the tank.  I dont know what the tank is for, but it is that thats stopping it coming out.  Any ideas?
That is the air con. Sorry doesn\'t help get ducting off but might stop you getting a leak in air con by not removing any pipes off it :)
