Coolant Buzzer
Started by dturpin, July 21, 2006, 08:06:26 PM
dturpin
I have just rebuilt my engine and am trying to fill the anti freeze back up but the coolant buzzer keeps going off.  There is coolant in the system as the filler neck is full. Could it be a possible sensor fault or would it just be that I still need to put more coolant in?
Its so annoying was hopng to have it ready for JAE, doesnt look good now though.
antnicuk
is the sensor connected?,  clear plug next to the filler neck.  There is also another plug and often gets confused for the knock sensor or air con. its a single black plug neer the crank angle sensors.
fro
If you can see water in the filler neck, it\'s probably the sensor. The sensor is on the front of the filler neck casting with a single wire coming out. Is the wire plugged in?
edit: I type toooo slooow :)
dturpin
There is deffinalty coolant in there, doe anyone know where I can get a sensor from, or if there is anything else I can do to at least stop the buzzer so I can drive it without going insane.
antnicuk
touch the wire to earth,  but you need to make sure the second black connector is connected.
dturpin
Connected to what? and where about is it in the bay usually, could be the problem.  Thanks for the advice.
antnicuk
look at my first post above
dturpin
I have found the conector but its not on anything, and cant see where to plug it onto.
antnicuk
it comes out of the main loom,   you may have the knock sensor, the power steering or the aircon IIRC connected to it.  You may have to have a root around the loom for it,
dturpin
Thanks for the help mate managed to find it after a lot of hunting about plugged it in and ts fine now.  Thanks again.
antnicuk
no problem,  glad you sorted it.
