where to put boost controller
Started by peterwolds, July 12, 2006, 11:23:36 AM
peterwolds
bound to get a rude response :Giggle
going to get it fitted looked around only place seems to be where radio/equalizer is on the dashboard means losing equalizer (not that worried if has to be).
any better alternatives its a profec b II,pics would be appreciated
Pete
:Typing Pete
AshRX
under the steering column? That where i have my turbo timer
shaunwil
I have mine on the top of the steering column and use it as my boost gauge too !
Shaun
peterwolds
Ash dont fancy it under,shaun thats a possibility cheers guys - day off tomorrow will have a good look round
Pete
:Typing Pete
shaunwil
gmogle
Mines in the glove box. Once its set you shouldnt need to see it anymore.
peterwolds
nice one shaun does the trick - cheers
Pete
:Typing Pete
peterwolds
Quote from: gmogleMines in the glove box. Once its set you shouldnt need to see it anymore.
point taken  i like to see gauges same with power fc commander always on display - thanks for idea
Pete
:Typing Pete
pete sparrow
Hi Pete
 Put mine in the holder/tray above the radio.Don\'t know if you\'ve got one of those in your car??
Pete
peterwolds
Quote from: pete sparrowHi Pete
Pete
Hi Pete
how you doing ?
got equaliser in there,think top of steering wheel looks best option so far - cheers anyway
Pete
:Typing Pete
dj_dee99
I\'ve got my boost controller & turbo timer on top of the steering column. Means you can see everything clearly all in one place.
peterwolds
Quote from: dj_dee99I\'ve got my boost controller & turbo timer on top of the steering column. Means you can see everything clearly all in one place.
looks the way to go
Pete
:Typing Pete
pete sparrow
Quote from: peterwoldsHi Pete
how you doing ?
Pete
Hi Pete
Good thanks.How\'s tricks with you?? Spending loads on your car i see??:chat
Single turbo conversion next???
Pete
peterwolds
Pete
Hi Pete
things are good.
wont go single am happily married :rollin - spends come to an end now just remap to go when last of these bits on then RX is like my evo was power wise
Pete
:Typing Pete
