3mm seal question.
Started by interloper393, July 12, 2006, 05:05:59 PM
interloper393
As a few of you might know im planning on doing a home rebuild but iv jus a quick question, if i use 3mm seals, then id need the housing machined right? so if ma housing was damaged, would it not be cheaper machining them for the 3mm seals rather than buying new housings? lol just thinking outside the box :Hammer
dandan
it\'s not your housings, but your rotors that would need machining. :)
interloper393
:2Confused  my bad lol.. cheers for that :cheers
