Water Injection Now Fitted !
Started by gsb876, July 01, 2006, 12:06:51 PM
gsb876
Finally got the WI fitted last week, many thanks to Paul (Wav) for coming over and taking the time to fit the unit engine bay now full too time to move the battery me thinks :cheers
Laeeq
Looking good bud...what boost setting is the water comming on?
Are you using big enough tank though as if its 150psi pump? it will go through loads of water..under:3gears-rh
Laeeq
gsb876
Quote from: LaeeqLooking good bud...what boost setting is the water comming on?
Water coming in at 0.7bar boost setting, using the windscreen water tank for the water provision :Giggle
shaunwil
Nice, but i\'d agree get that battery in the boot !!! Will you get it tuned to be set on water ???
Are you at next mascarat ?
Shaun
gsb876
Shaun,
Mascrat is diffecult for me as work Mon - Fri on a 3 shift rotation so the only real time i can make it is either on hols or bank holidays. So will not be at next meet matey :Giggle
shaunwil
No problem mate, always good to see you !
Shaun
Those pics look the same, or is it just the amount of beer I\'ve drunk today?
Where are you injecting the water?
gsb876
C\'mon Fishy,
The canister is right in the middle next to the battery the white cables are for the water injection, being injected after the elbow area before the gold starts :cheers
Right off to see England now !!!! :cheers
probedb
So where\'s the Pepsi bottle...I thought Freddy had set the standard...or was it Sprite or Tango? ;)
Quote from: gsb876C\'mon Fishy,
Yes I can see the motor, but the pipe looks like it goes back to the ABS unit. :p
gsb876
#10
Had a quick blast earlier today, air intake reading 42oC had a quick blast with WI on, went from 42oC down to 30oC quite quickly after a couple of runs, quite good this WI stuff eh ? :Thumbs-up
Bulla
What kit did you go for Gurj ?
Bulla
gsb876
Quote from: BullaWhat kit did you go for Gurj ?
Bulla
Err not the aqua mist one but another one designed by Wav, he\'d be better to ask tbh:Thumbs-up
