Clifford alarm won\'t go into valet mode?
Started by probedb, July 07, 2006, 09:06:33 PM
probedb
Hi all,
For some reason my alarm has decided it won\'t go into valet mode anymore.
It was left in valet mode in the garage for 2 weeks or so, then started the car and drove around a bit which obviously knocks it out of valet mode.
Problem is now pressing the two buttons to put it in valet mode does nothing :( Any thoughts on what might have happened?
Can\'t put the PFC in because of this as I need to disconnect the battery.
Ta!
antnicuk
from memory, does the ignition need to be on to go into valet mode?  Just a thought
probedb
It never has before but I\'ll give it a go and see. Turning it on always kicks it out of valet mode tho can\'t remember whether it was ignition or on that made it switch out.
dwarfslapper
Turn on the ignition on then disconnect the battery fit the PFC then the same to to reconnect it the alarm shouldnt go off if that helps
Paul
For sale:Thumbsup! http://www.mazdarotaryclub.com/forums/showthread.php?t=34314
High maintenance,but aren\'t all beautiful girls:InLove
probedb
Cheers for the info I\'ll give it a go.
