Early engine thrust bearings - for info
Started by db2boy, June 11, 2006, 08:39:58 AM
db2boy
Folks,
  Have slowly (no time and waiting for parts from Japan) been re-building the RX-2 12a. Had this litttle issue where no matter which of the 4 available spacers I tried I could not get any end play - now I like building tight motors but not that tight :)
Replaced one of the front thrust bearings with a later model one. Now you might think they would be the same as early ones - oh no! They look the same but on much closer inspection the modern ones are very very slightly thicker (sorry I didnt measure but can if required). I quickly changed it over for one from my 10a parts box and voila I had end play back!
So for information those who are building early engines you need to either a) get the early bearings (going to see if I can get stock from Japan this week) b) be prepared to have an over sized spacer made if you want to use modern thrust bearings.
Thanks to Geff for popping over and banging heads with me and suggesting we should check this.
Rgds
Ant
'73 RX-2
'95 20B Cosmo
'91 20B Cosmo
oldone
Checking the spacers is always the last thing on a persons mind on an engine rebuild.....you always assume they are correct !!!!!....Thanx for sharing the info  :cool , top marks to Geff..just shows how differant he thinks...  :Typing
db2boy
Quote from: oldoneChecking the spacers is always the last thing on a persons mind on an engine rebuild.....you always assume they are correct !!!!!....Thanx for sharing the info  :cool , top marks to Geff..just shows how differant he thinks...  :Typing
yup all I thought was - yup that is all good, new and shiney, not crushed! Confused Geff at first as everything else was spot on!
Ant
'73 RX-2
'95 20B Cosmo
'91 20B Cosmo
travellinbob
Hey thats pretty cool info Any. it is little things like that that can really scupper an engine builder. Cheers for sharing.
p.s. are you the guy from stert garage with all the old skool stuff? if so then would it be cool for you to send me an e-mail for a chat about stuff?
 float7@@hotmail.com  (fix obvious mistake as it keeps the spammers from my poor little hotmail account) cheers,michael.
db2boy
Quote from: travellinbobHey thats pretty cool info Any. it is little things like that that can really scupper an engine builder. Cheers for sharing.
Yup one of those things that isnt obvious straight away!
No Im the guy from Portsmouth with all the old skool stuff :) Email on way.
Ant
'73 RX-2
'95 20B Cosmo
'91 20B Cosmo
