GT35 Turbo For FC ?
Started by paul3944, May 30, 2006, 04:57:05 PM
paul3944
Hi All,
Have the following turbo but not sure if the compressor side is large enough I\'ve tried to research but it\'s getting all a bit confusing!!  :Hammer
Spec as follows-
Garrett GT3571
Comp A/R = 0.50
Ex A/R = 1.06
Paul    :3gears-rh
shaunwil
Have you had a look on rx7club in the single turbo threads ???
Shaun
paul3944
Yes Mate,
That forum has really gone down hill  :Yawn
The only answer you get is (Why bother I have these in stock $$$$$$$$)
or
I hoped you searched.
I\'m looking for quite possibly 300bhp, would this turbo be suitable?
Many thanks
Paul
shaunwil
paul3944
Thanks mate for the info
Checked on the Garrett site should make up to 390bhp
Nice one   :)
Paul
If it helps i used to have a Gt35R with a .7 Cold side and a .96 T4 Hotside. When i bought it the Guy i spoke to said the T3 Turbine Housing on the std Gt35 was too small for a Rotary hence why i went for the T4 set up.
Be carfull selecting a Turbo off the Garrett Figures becouse there taken rougly from Figures produced by Piston engines, they always seem to produce higher HP on smaller turbo\'s :)
#6
Quote from: paul3944Yes Mate,
or
Many thanks
Paul
Yeh most of the Big names have got fed up with the Bull s**t flying about, So alot have moved to Nopistons but the problem is the muppets do tend to follow...
I kind of understand why they say search!!! all the Time, The amount of old Info on the Site is massive!!! 99% of the time you can save time by searching but you do get people asking the Noob questions then a week later some one else will ask the exact same questions without looking first. You see it all the time so i can understand to a Degree.
paul3944
Thanks for the reply mate
I\'ve searched that forum and others until my eyes were bleeding!!
The threads soon breakdown into a bunfight and the info given is usually wrong  :Nono!
Just glad you can a straight answer on here without all the crap  :cool
Oh and the turbo I guess I\'ll just whack it on see what the results are.
Paul
