Fitting Short Shifter
Started by AshRX, May 17, 2006, 01:38:26 PM
AshRX
Just received my short shifter from Clive  :cheers
Can someone please explain the easiet way to fit them. I took the arm panel and gear knob off and all that was under there was insulation foam and a large black platic cover.
I have heard these are easily fitted but having probs working out what goes where.
If someone could explain point by point that would be great.
Undo the 4 10mm socket sized nuts and you will lift the tunnel cover off and then you will see 4 12mm socket sized bolts to remove and the whole gear shift turret will pull off the top of the gear box.
You will then need to pull off the nylon cup from the base of the origonal gearleaver and fit this to the new B&M shifter.
AshRX
Cheers what about the large clip that comes with the new shifter?
GerbilStuntFarm
That bit\'s in the instructions.
