Mapping Question
Started by gadj, May 15, 2006, 09:24:07 PM
gadj
So, the question is, is mapping something you should do like as regular maintenance? Or is it something you just do once, and then just when you change something or modify something?
Had it mapped at Re:Worx on their rolling road - just wondered if its something I should consider doing every so often?
sdminus
It wont hurt to fettle the map every so often. Over a period of time things will change on you set up and you can kepp on top of things. Temp correction factors and such can be alterted to suit your driving as well as triming the timing and fueling to get a really good and close tune.
You could fettle the map forever. In a nut shell you can not get the best map for your car in 2 hours.
Scott
I used to run winter and summer maps on the scoob. But its a lot easier to swap on a MoTeC.
sdminus
Quote from: FishI used to run winter and summer maps on the scoob. But its a lot easier to swap on a MoTeC.
There is really no need to  if the temp correction factors are fettled correctly. IMHO the motec is far superior to the power fc anyway.
