EGI ICV to TII?
Started by Sarah, May 09, 2006, 07:36:58 PM
Sarah
Hi all, Nik here. Quick question...... Will the ICV (idle control valve) from Sarahs EGI fit on the TII? The idle is very lumpy and it has stalled occasionally. Just thought I\'d give it a try unless anyone has any other suggestions?
Nik
t2rew
you could try to clean it out with carb cleaner first. make sure theres no crap in it.
Take a look at the following link:
Cleaning the Bac valve - courtesy of 1300cc.com
Rough idle could also be down to a leaky air hose - so check your hoses, and a faulty 02 sensor or lead come lose.
Sarah
Thanks guys, I will give it a go this weekend :)
