turbo timer prob
Started by yamaster, March 05, 2007, 09:16:09 PM
yamaster
ive got a hks turbo timer and wired up with the harness the problem is when i leave it runing it wont set the alarm only lock the doors and when it does turn of it opens the doors  lol   any quick way to fix this problem?
also the taco needle jumps like crazy between 2 and 3.5 rpm and then goes back to normal what would cause this??
yamaster
can anyone help me out??
RobbieRX-7
When it turns off it opens the doors, that sounds like you have the unlock/lock wires crossed somewhere. The tacho sounds broke to me, it is a pretty common fault -something to do with the resistors on the back, best to get another second hand off here
yamaster
Quote from: RobbieRX-7When it turns off it opens the doors, that sounds like you have the unlock/lock wires crossed somewhere. The tacho sounds broke to me, it is a pretty common fault -something to do with the resistors on the back, best to get another second hand off here
any idea what colour wires these would be? and the alarm wont set either when its running kind of defeats the purpose of a turbo timer lol
m4drx
you cant arm almost any alarm as the ignition is still on so its the same as it arming while you\'re drving some very exprnsive systems can be upgraded to offer this.
fduk.
