clutch??
Started by chrisJDM, April 11, 2006, 10:41:13 AM
chrisJDM
Yesterday pulled up at the lights next to a hyundai coupe who decided to start revving his engine so thought i had betta kick his ass, when lights changed accelerated hard and pulled the clutch up but didnt quite pull it up quick enough and the car went but then there was a really bad strong smell and white smoke coming in through the centre from gearbox area, is it prob the clutch???
banned advertiser
Doubt its a problem its just the clutch has slipped and burnt, mine would do it at Santa pod but was fine generally, you have just slipped it to much, held it off of top too long.
K1HKS arse
Yep,fryed a few thousand miles off your friction plate mate.That smell will stay for a little while aswell!!!!!!!!!
chrisJDM
o dear nevamind at least its nothing to major, clutch still feels ok at mo but was prob gona eventually change it when ive added a few more mods.  Cheers  :burnout
banned advertiser
It will feel fine and as Gary (Hi) says you have burnt off a few miles, but unless doing it regularly or up the strip you could get thousands of miles out of your clutch, next time just remeber to not slip her so much and you will be fine. Only start to worry when it slips when not pulling away, ie you just put your foot down to acceerate and it starts to slip, then its time for a new one.
chrisJDM
Do you still have the same free play at the top of the pedal as you did have.
If you have killed your clutch the first signs on a twin turbo car are that as the second turbo kicks in whilst driving the car the clutch slips, so if you have free play and if its O/K on hard acceleration you should be OK  :cool
