FD in Japanese Performance Mag
Started by G@NDY, March 21, 2006, 08:57:34 AM
G@NDY
Has anyone got the latest offering of this mag with the white single turbo FD in it? I still cant believe that he is running a single turbo on 0.9 boost on standard injectors!!! and with no boost controller, just working off the wastegate. :2eek He may have added an uprated fuel pump, but surely those injectors must be maxed out. Not ideal to run the engine lean, with all the money spent on the car, i just think why?????? :Hammer  :xconfused
BlitzBoy
They run 100 octane in Japland thats probably why he hasnt detonated
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
G@NDY
good point mate, never thought of that. :)
Iwan
Quote from: G@NDYHas anyone got the latest offering of this mag with the white single turbo FD in it? I still cant believe that he is running a single turbo on 0.9 boost on standard injectors!!! and with no boost controller, just working off the wastegate. :2eek He may have added an uprated fuel pump, but surely those injectors must be maxed out. Not ideal to run the engine lean, with all the money spent on the car, i just think why?????? :Hammer  :xconfused
Depends on Turbo- setup.  If this one is a, for example, T04E with 50 or 47 th compressor, you will never run lean as this smal turbos will provide just the ammount of the twins. So all this depends on the setup.
REgards
Iwan
still remember,
NO ROTOR, NO MOTOR !
McCARTHY
its got a TD06 25G, 43mm external W/G, mechancial boost control fixed at .9bar. According to the write up 550cc and 720cc injectors.
great looking car
sadgoth
720cc? so let\'s get this straight, he\'s reduced the size of the secondaries? More likely JP are being inaccurate again!
Mark
89 Black FC3S Turbo II
Loud? Hell yes! :D
McCARTHY
Thats what it says in the write up
