Exhaust Studs and Nuts Supply?
Started by db2boy, February 21, 2006, 08:28:30 PM
db2boy
Well before I could put the RX-2 lump back in I had to get out a badly damaged exhaust stud - the welder acheived that this evening :)
Ive been trying to locate a supply of exhaust studs and nuts to complete the job over the last few days. As good as the interweb is Ive not come up with much apart from a large box of mixed ones - and I dont want this.
Can anyone suggest a supplier of exhaust studs and nuts? Im looking for M10x1.25
Rgds
Ant
'73 RX-2
'95 20B Cosmo
'91 20B Cosmo
Halfords used to stock them. Take one in with you, as they are known to supply the wrong items. ;)
If not give Iain a call at Hayward and Scott in Basildon, Essex. He\'s a good chap who should help you out.
banned advertiser
Not sure if they can help but they are a big nut & bolt distributor.
W.M Owlett & Sons Ltd
Sandpit Rd, Dartford, Kent DA1 5BQ
Tel: 01322 277733
db2boy
Thanks for the input guys :) Didnt think Halfords did much useful beyond camping equipment! Ill try both of those out. I tried a local fittings specailist - they had everything but automotive hardened bits. Tried to convince me normal studding would do it, until I tried to explain what it was for and how hot it would get :)
Rgds
Ant
'73 RX-2
'95 20B Cosmo
'91 20B Cosmo
The other place might be worht trying is somewhere like slow-fit, sorry I meant Kwik-Fit. The fit exhausts of a kind, and might also carry some spare studs.
Martiny
Thtas a great tip Gary. i have been searching and searching for a nut and bolt supplier.
Ant, so it will be at Brooklands, then?
db2boy
Quote from: MartinyThtas a great tip Gary. i have been searching and searching for a nut and bolt supplier.
Dont make me go to quickfit, please dont :) A good thought though, thanks!
Martin, we have good local fittings shop - no good for you though I guess. Screwfix can be OK depending on what you want and quantity.
Well if I can find the time to get her on the road it would be nice.
Rgds
Ant
'73 RX-2
'95 20B Cosmo
'91 20B Cosmo
Carl
Just let me know exactly how many you want and I\'ll pull the studs from some stuffed rotor housings.
The nuts are stainless,and I can get them too.
Regards
Carl
