Handbrake light stuck on
Started by ramirez, December 31, 2006, 04:34:25 PM
ramirez
Since this motning in my TII the handbrake light only seems to go out under hard acceleration and then comes back on . Its tipping down outside so i can\'t check a lot but the brake fluid level is definitely ok.
Could this be a case of stuck rear calipers? Anything else to check?
RAW
i have exactly the same on m FD! only comes under hard braking or acceleration. think it may be a loose cable/sensor connection?
Mobilemick
Check to see if ur switch isnt stuck on the handbrake ?
R32 Nik
I would check your pads as I think the hand brake light is also a warning for the brake pads being low.
Brett
Yep, what Nik said - bet your Brake fluid is low due to worn pads :yes
Brap Brap Brap Brap
ramirez
hmm thats the weird thing the fluid is bang on :S
RAW
visually inspected the pads and there seems to be plenty left. having the fluid changed on friday so we will see!
royal
Isn\'t it a known problem with the FD? I\'m sure I read it on one of the websites, the one where the guy has done a guide to modding the car.
