Underdrive pulley kit
Started by nikp, November 18, 2005, 10:20:50 AM
tr1cky
Quote from: sweetiewellshave rxmotors got a web site?
//www.rxmotors.co.uk
kinda obvious really :rollin
Rich
The FC is dead, long live the FD
chrisJDM
lol to be honest was to lazy to try and guess it
LRP
royston1 do you no what length belt is req when the underdrive pulleys are fitted ?
complete wankel :god
LRP
as i seem to be chargein at 15 volts at the most thought the alternator would of governed this ? the underdrive pulleys are bigger so less revolutions i persume?
Pointman
I have a Dragon Underdrive Pulley kit, but also wish to remove the aircon. Does anybody know what size of belt I need as the supplied one is too big ??
DRAGON
Air-pump removal and Air-con removal are two different things.
All you need to remove the Air-con is a smaller belt, we have these in stock.
I would not recommend JUST going for a smaller belt if you remove the Air-pump, in fact I would refuse to do it to a customers car. You will get a very small amount of contact on the water pump pulley, and as water temp cooling is so important to your engine, its not something to take a risk on.
Pointman
Could you tell me what else I would need to have done please ?
Unfortunately you are a: Too far for me to travel to and b: My rex is currently in bits being painted.
Many Thanks  :cheers
DRAGON
You need the underdrive kit to remove the air-pump. And just a shorter belt to remove the Air-con.
Pointman
Many Thanks.
As far as I know the air pump has been removed along with all of the Air-Con system. Will go have a word now with the mechanic and see what has exactly been done, then try and give you a bell for the belt.
Thanks again  :Thumbs-up
